Date/Time: Tue, 26 Nov 2024 04:31:54 +0000
SpreadSheet Question
View Count: 904
[2014-04-14 20:19:36] |
infpz - Posts: 826 |
I have a %B study value in column AA. I am looking to buy if the %B is lower than 0 or sell if it is higher than 1. Can someone assist with which formulas would go in K3 and M3? I am not worried about exit strategies. Would it be: K3: =AA3<0 M3: =AA3>1 I am working off the examples on the site, and they work if the criteria we are using is the last price, but in this case I don't care about the last price, only the value of %B. Thank you |
[2014-04-14 21:10:09] |
These formulas look correct. Have you tested them? Is there any problem.
[2014-04-14 21:19:02] |
No, everything appears to be working. Thank you.
