Date/Time: Thu, 19 Sep 2024 21:43:20 +0000
TPO Count from Previous day Settlement
View Count: 2180
[2014-04-14 15:40:56] |
Discount - Posts: 73 |
How do I get the TPO Count from Previous day Settlement? I am trying to figure out is TPO count long or short from previous day settlement? Thanks
[2014-04-14 17:39:18] |
The first step is to set the Session Times for the chart according to exchange rules. Here is the documentation for that: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes After this you can view the Total TPO Count through the TPO Profile Text Information: https://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TextInformation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-15 03:41:33] |
I must be having a tough time with your platform. I have got the times in the chart settings correct. I have the TPO study showing, and in the windows tab, I have the chart value window and the tools values window checked, but when I take one of the tools, either the pointer or the crosshairs, I still can not get the chart values window to show. Is there something else I have missed, or not checked off? |
[2014-04-15 03:47:56] |
You need to use the Window >> Tool Values Window to see the TPO values for TPO profiles other than the last one displayed.
[2014-04-15 03:54:09] |
Okay I did check that one and again I am still not getting the data window to show up. Any other ideas? Thanks
[2014-04-15 04:02:08] |
If you do not see any window become visible or hidden when you select Window >> Tool Values Window, then select Window >> Reset Windows and try again.
[2014-04-17 20:22:06] |
HI,, I reset the windows, and not I am getting the TOOL VALUES WINDOWS, AND ON the TPO Profile, I have to use the Chart Value windows. But How do I get the TPO Count from Previous day Settlement? I am trying to figure out is TPO count long or short from previous day settlement? Market Delta and other platforms can tell you this, but I am not seeing that info on yours. I see that there is the TPO's above / Below POC, but that is not the same as the TPO count from the last settlement. What I am trying to find out when I come in in the morning after globex, is the market net long or short. Typical Market Profile stuff. Thanks Nick
[2014-04-17 22:25:03] |
This is not making sense. If you select Window >> Reset Windows and then Window >> Tool Values Window, you are going to get the Tool Values Window to appear. There definitely should not be a problem with this. And what you want to look at is the Total TPO Count in either the Tool Values Window or the Chart Values Window. Here is the documentation for those here: https://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TextInformation And how you would figure out whether the total TPO count is long or short from the previous day settlement, we have absolutely no idea. That makes completely no sense. Whoever is talking about something like this, either does not know what they are talking about, you are misunderstanding them, we are misunderstanding them, but we are only basing what we are saying what you are saying, or they are taking advantage of someone's ignorance. We cannot see how a TPO count could be long or short. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-17 22:26:01
[2014-04-17 22:49:24] |
Sorry, the term THEY use is or the question is " Is the overnight inventory long or short" And how they figure that is by the TPO count after settlement. Now can you tell me how I can figure this in Sierra Charts? Thanks
[2014-04-17 22:58:15] |
This is not good terminology they are using or even logical. The only thing that we can reason is that maybe they are counting the number of TPO's above the prior settlement price and below the prior settlement price. This does not tell you anything about long or short though. That cannot be determined. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-28 20:47:00] |
I am studying with Jim Dalton, author of Minds over Markets and other market profile book and courses. What I previously was trying to ask is there a simple way on the TPO chart to tell the TPO count that are above and below that days cash settlement? Thank you for your help |
[2014-05-29 16:52:11] |
One question is for TPOs which are equal to the settlement price, should those be considered above or below it?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-30 09:45:34
[2014-05-29 18:03:11] |
English is my main language, and pardon me for my ignorance, but I do not understand your question. I have asked you this question: What I previously was trying to ask is there a simple way on the TPO chart to tell the TPO count that are above and below that days cash settlement? That is my question. Or let me rephrase it. Question 1 is, I am trying to figure out in the overnight Globex before the US Cash open, Is there a simple way to figure out the TPO count ABOVE the previous days settlement? Question #2 is, I am trying to figure out in the overnight Globex before the US Cash open, Is there a simple way to figure out the TPO count BELOW the previous days settlement? Can you answer that please. Thanks |
[2014-05-30 09:46:45] |
You are correct. The question was not worded properly. The way it was worded previously, made no sense. This is what we meant: One question is, for TPOs which are equal to the settlement price, should those be considered above or below it?
I guess we will just disregard those TPOs. To answer your most recent question, this capability does not exist but we will make a note to add it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-30 16:10:00
[2014-05-30 12:14:01] |
Great, please let me know when or if this improvement has been made. Market Delta and Investor RT has a feature where you put your pointer on any particular TPO, and in a data window, it will show a + number and a - number, showing the TPO's above and below settlement at that time of that TPO. Thanks |
[2014-05-30 16:10:24] |
OK, we will be adding this feature as well.
