Date/Time: Thu, 06 Mar 2025 19:08:04 +0000
Remove
View Count: 508
[2022-02-12 16:56:54] |
Trader8188 - Posts: 20 |
Hi, when users export trade activity log in .txt format there is additional text "log" beside DateTime that needs to be remove in order for the import into Tradervue to work. ActivityType LogDateTime Symbol OrderActionSource InternalOrderID ServiceOrderID OrderType Quantity BuySell Price Price2 OrderStatus FillPrice FilledQuantity TradeAccount OpenClose ParentInternalOrderID PositionQuantity Should be DateTime only |
[2022-02-13 00:11:52] |
The internal name of that variable has changed but we will keep the external name the same in the next release.
