Date/Time: Tue, 18 Mar 2025 21:55:59 +0000
Trade Account Monitor
View Count: 1084
[2022-02-11 19:11:20] |
SierraTraders - Posts: 69 |
When in "Live Mode" the Trade Account Monitor Window shows a error (see attached) when trying to edit any options like (comm, margins, daily lost, etc. |
[2022-02-11 20:09:13] |
You cannot edit a live trading account. This can only controlled by a clearing firm or a broker. We will be supporting, over the next couple weeks the ability to see the values but you will not be able to change them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-11 20:09:52
[2022-09-20 09:45:37] |
User 144164 - Posts: 17 |
220920-0443 RE: Trade account monitor / Balance window Services used are: Teton Order Routing, Denali Data, Stage 5 Broker 1. Is there any way to show a beg and end date - in other words show multiple dates. 2. If not, is there any other window that shows the profit-loss and end balance for an account with the option to choose beg and end date. FYI I have been trading several decades and SC is the most comprehensive and best chart service ever used. Thank you in advance!! |
[2022-09-20 10:03:39] |
Sierra_Chart Engineering - Posts: 18824 |
Yes you can do this through the Trade Activity Log: Trade Activity Log You can use the control at the top left to show only "Account Balance" data. For historical balance data when using Teton order routing, make sure you are running a current version. Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-20 11:05:19] |
220920-0603 RE: Trade account monitor / Balance window Thank you for your INSTANT reply! 1. Account balance view does not display fills 2. Fills view does not display account balance 3. Is there any view that displays both account balance and fills? Or one as a pending feature? 4. Is there a pending feature that would display trade fee separately (now in order-action-source column)? The Export feature is excellent! Thank you in advance for your one-of-a-kind service! |
[2022-09-21 15:09:46] |
3. You can do this through the Trade Activity Log and set the filter control at the top left to "All Activity", to see account balances and fills at the same time. 4. Definitely this is not going to to be added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-21 15:10:09
[2022-09-21 20:09:52] |
220921-1509 RE: Trade account monitor / Balance window Thank you for your reply. I am aware of what you say. I should have been more clear. I am looking for FILLS and BALANCE in the same view ONLY with NO OTHER activity. Thank you in advance for your GREAT PROFESSIONAL SERVICE! |
[2022-10-01 19:31:56] |
221001-1431 Please reply to the post above of 220921-1509. This is the question I have desired to be answered from the beginning. To view the FILLS and BALANCE in the same view ONLY with NO OTHER activity. The solution provided by SC Tech included orders. The need it so EXCLUDE all other activity. Thank you in advance for your reply. Kind regards |
[2022-10-02 01:07:57] |
No, this is not supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-02 01:08:03
