Date/Time: Fri, 07 Mar 2025 01:01:37 +0000
Price retracement tool - alert feature
View Count: 679
[2022-02-11 15:12:02] |
countryboy92 - Posts: 91 |
I use the price retracement for drawing zones. Can I add an alert function that beeps when price hits one of the price retracement lines?
[2022-02-11 17:48:13] |
John - SC Support - Posts: 38467 |
For the Price Retracement drawing, the only option for creating an alert is based on the Anchors. Refer to the following: Study/Chart Alerts And Scanning: Reference by Anchor For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-22 01:49:15] |
I was testing the alert function with simple closing price is greater or lower, and a log came up showing my alert came true a couple times, but there was no sound. I selected "alert 1" and tested that sound in the global settings and it sounded fine (1 beep).
[2022-02-23 15:15:30] |
Refer to the following: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
