Date/Time: Thu, 06 Mar 2025 18:48:42 +0000
Non-zero values for Maximum Show Quantity
View Count: 536
[2022-02-11 14:55:44] |
sgne - Posts: 109 |
Can a non-zero value for Maximum Show Quantity be saved to a trade window configuration?
Date Time Of Last Edit: 2024-12-05 03:57:04
[2022-02-11 17:36:17] |
John - SC Support - Posts: 38446 |
We are not understanding the question. The Trade Window Configurations are for settings on the Trade Window. There is nothing on the Trade Window related to "Max. Show Quant.", so we are not sure what item you are specifically referring to. Can you give us more information on what you are wanting exactly.
[2022-02-11 18:50:37] |
We will make sure the Maximum Show Quantity number gets saved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-11 18:50:48
