Date/Time: Tue, 29 Sep 2026 06:48:00 +0000
Delayed data
View Count: 1034
| [2022-02-11 12:55:33] |
| User6929 - Posts: 5 |
How do I get live data into my charts? Instructions tell me how to transition from live data to delayed data which I've tried to reverse the steps to get the live data, but to no avail. I've got a live broker account, Teton order service, and my "Common Other Settings", "Allow Support for Sierra Chart Data Feeds" is set to "Yes" I'm running the current SC Version 2348. I'm on a SIM and want live data on SIM. Is that possible? Thanks. |
| [2022-02-11 14:16:33] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
| [2022-02-11 14:42:29] |
thanks for responding. NQ (micro and mini futures) and ES (micro and mini) |
| [2022-02-11 15:00:46] |
Therefore, complete the CME related agreements here and also activate the CME exchange: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-11 15:00:54
