Date/Time: Thu, 06 Mar 2025 18:53:44 +0000
How to show P/L on all positions on DOM
View Count: 562
[2022-02-11 07:54:38] |
Bhupinderjhajj - Posts: 30 |
Hello! I'm looking to trade spreads (going long on NQ short on RTY ect) Is there a way to show the total P/L between the two? Example NQ is up 500 but RTY is down 450 so a total P/L of $50. Also is there a way to flatten all positions on both assets. So if i'm up cumulative $150 I flatten and lock in that profit. I find if I flatten one at a time or if cumulative profit is close the execution can get messy and I can lose some money that I didn't have to. Thank-you Bhupinder |
[2022-02-11 14:44:47] |
There is not good support for what you are looking for at this time in Sierra Chart. These are considered separate symbols and all the data and functionality you are asking about is supported for them individually but not together for two specific symbols.
