Date/Time: Thu, 06 Mar 2025 19:13:24 +0000
3-day rolling Pivots
View Count: 957
[2022-02-11 04:41:30] |
kienly03 - Posts: 13 |
I've searched the support forum for solutions re a 3-day rolling pivot indicator and also flipped through the 28 formulas already available however could not quite find what I was looking for. Can you pls advise if: a) there's a formula available that maybe I've missed; b) a way for me write my own script; or c) get assistance to get the following added? Three-day rolling pivot price = (three-day high + three-day low + close) / 3 Second number = (three-day high + three-day low) / 2 Pivot differential = daily pivot price – second number Three-day rolling pivot range high = daily pivot price + pivot differential Three-day rolling pivot range low = daily pivot price – pivot differential thanks |
[2022-02-11 16:57:34] |
John - SC Support - Posts: 38447 |
a) There is not a formula for this already in the Pivot Points study. b) You can create this yourself using either the Spreadsheet Study (with other studies that you may need), or you can edit the existing study or write your own custom study. Refer to the following for the Spreadsheet Study: Using the Spreadsheet Study Refer to the following for how to build a study, which also includes a section for how to find the existing source code How to Build an Advanced Custom Study from Source Code c) It is not something we would do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-11 20:34:46] |
Sawtooth - Posts: 4181 |
Here's one built with the Spreadsheet Study study:https://www.sawtoothtrade.com/free-stuff-3.html |
[2022-02-11 21:41:54] |
Thanks for your assistance!
