Date/Time: Thu, 06 Mar 2025 18:59:09 +0000
Connecting multiple accounts
View Count: 678
[2022-02-10 18:36:08] |
maliik3103 - Posts: 48 |
i activated order allocation to trade multiple accounts , and connected 2 accounts. but when i place a trade , it does copy the trade to the other account but its reversed, so when i buy on the first account, it sells on the second. but i need them both to place the same order. what to do ?
[2022-02-11 01:24:00] |
Sierra_Chart Engineering - Posts: 18669 |
The same order must be placed. You can verify that in the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity You are also running an out of date version and you need to update to the current version. Instructions: Software Download: Fast Update We will not provide support for an old version. After the update follow the instructions here to use Rithmic: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-11 10:10:42] |
if i update to the new version, will i keep the files which i added to the current one? Because i have added a new file in order to be able to use rithmic , will this be able with the new version as well?
[2022-02-13 01:03:16] |
First regarding Rithmic, refer to: Rithmic Trading Platform Service: Rithmic Support Policy We are not sure what files you are referring to but you can continue to use your same Chartbooks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
