Date/Time: Thu, 06 Mar 2025 19:23:16 +0000
[Programming Help] - profit/loss
View Count: 525
[2022-02-10 15:44:35]
User415862 - Posts: 13
I'm not sure if my p/l is correct. I'm sim trading the ESH22_FUT_CME. In chart settings the price display format is .01, tick size is .250 and the vol at price mult is 1. Is this correct? I have a trade window for the chart open. I'm in currency value in the advanced tab-settings.
Thank you. I have been reading all about it and am still confused.
Date Time Of Last Edit: 2022-02-10 16:03:06
[2022-02-10 17:46:00]
John - SC Support - Posts: 38450
You need to make sure that the Currency Value per Tick is set correctly. In general for the ES this should be 12.5 to convert to U.S. Dollars. Refer to the information here:
Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
