Date/Time: Thu, 06 Mar 2025 18:58:47 +0000
Chartbook Windows Always Visible But Don't Show Unless Tile As Grid
View Count: 559
[2022-02-10 05:24:45]
User379468 - Posts: 508
Using several chartbooks with the charts overlaid over each other, attached in Main Sierrachart window, all set to Always Visible. When switching chartbooks, usually the correct charts in the newly selected chartbook show up.
Recently, only the last selected chart has been showing up when switching to a different chartbook, the rest remain from the previous chartbook.
Only by switching chartbooks AND selecting Tile as Grid, do the correct ones from the newly selected chartbook show up.
Can anyone please help with this?
[2022-02-10 16:16:04]
John - SC Support - Posts: 38446
What you are describing sounds like correct functioning since you have the option for Window Always Visible selected for the charts in the first chartbook. That option makes the charts from another chartbook visible when selecting a different chartbook. Refer to the information here:
Window, CB and CW Menus: Window Always Visible (Window)
