Date/Time: Thu, 06 Mar 2025 16:08:48 +0000
Locking an individual pull point to a specific part of the candle without affecting pull 2
View Count: 512
[2022-02-09 20:35:42]
User773081 - Posts: 26
Is it possible to tell each individual pull point on Fibonacci expansion to lock to a specific point on the candle without affecting point 2? I see the ability to right click and snap to the high/low/ open/close but this effects both pull points in tandem. In some cases I want to lock it to both lows or both highs/ a candle close and a high etc but I have yet to find the option
[2022-02-09 21:55:15]
John - SC Support - Posts: 38438
There is not a built in option to specifically force one anchor to a position and then force another anchor to another.
You would just have to adjust each anchor point individually to get what you want. It can be helpful if you use the Auto Snap option. Refer to the information here:
Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values
