Date/Time: Thu, 06 Mar 2025 16:13:30 +0000
Different Volume in Historical Chart compared to Intraday Chart
View Count: 535
[2022-02-09 20:04:25] |
User551647 - Posts: 23 |
Dear Sierra Team, I noticed that there is a different volume in the historical ZWH-22 contract compared to the intraday chart. As you can see in the pictures, the volume in the historical chart on February 6th/7th is greater than on the day before. In the intraday chart it is smaller. Where does the difference come from? In the intraday chart I use the full 24h session, so the night session is included. Many thanks in advance! https://www.sierrachart.com/image.php?Image=1644435255922.png https://www.sierrachart.com/image.php?Image=1644435343437.png |
[2022-02-09 21:46:50] |
John - SC Support - Posts: 38439 |
Refer to the following: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
