Date/Time: Mon, 05 Oct 2026 17:11:18 +0000
Holding Pivot Values as Subgraphs
View Count: 885
[2022-02-09 18:34:44]
User337568 - Posts: 65
Before approaching a professional coder, I wonder whether I can get access to previous pivot values as subgraphs.
I think this can be accomplished through an array. However, I don't know.
Also, I have looked at other private scripts, and I cannot access previous pivot values.
So, using the native Swing High/Low script, I want the following
1. Hold the recent pivot values.
2. Determine if a subgraph value is higher or lower than 1 ago.
3. Allow equal bars
4. Use intrabar or close
[2022-02-09 19:11:11]
John - SC Support - Posts: 48101
You can do this using the Spreadsheet Study. Otherwise, it would be something that would need to be coded.
[2022-02-09 19:27:46]
How would a coder do it?
Is it an array or something else?
[2022-02-09 21:36:18]
It's hard to say how they would do it, as there are a lot of different ways, and it depends a lot on what exactly you want and how you want to use it. But in general, keeping the data in an Array would make sense.
[2022-02-10 02:07:39]
Sawtooth - Posts: 4355
I answered this in post #4 here:
Swing High Low - Accessing Subgraph values
