Date/Time: Thu, 06 Mar 2025 16:13:48 +0000
Chart DOM quantity Scale Spread
View Count: 694
[2022-02-09 18:24:44]
DianaPena - Posts: 33
I was wondering if there was a setting where I can change the scale of the DOM quantity on the chart DOM, to only show the quantity for the prices that are being shown on the chart, instead of showing it for every tick price. I know I can zoom the chart and the quantities will look spread apart, but I'd like to be able to zoom in/out and only show the quantities for the prices on the chart, so they wont look all bunch together.
Thanks!
imageDom Price.png / V - Attached On 2022-02-09 18:24:21 UTC - Size: 46.03 KB - 149 views
[2022-02-09 19:10:15]
John - SC Support - Posts: 38439
The only option for this is the following setting where you can specify the number of ticks to combine together:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
With the Market Depth Historical Graph, you can have it adjust automatically as you scale up/down. Refer to the following:
Market Depth Historical Graph: Automatic Combine Increment Adjustment Value
[2022-02-09 19:30:40]
Awesome! That was exactly what I was looking for. I knew I had seen it before, but couldn't remember. Thanks!
