Date/Time: Thu, 06 Mar 2025 16:18:45 +0000
move attached stops to price
View Count: 746
[2022-02-09 17:48:57] |
User377342 - Posts: 14 |
How do I insert the "move attached stops to price" on the DOM. I see the instructions on how to use it. However actually placing it on the DOM is not showing up anywhere. Please advise.
[2022-02-09 18:57:18] |
John - SC Support - Posts: 38440 |
You can set it up by adjusting your Chart DOM Settings for the mouse action in the DOM. Refer to the information here: Global Trade Settings Windows: Chart DOM Settings Or you can add a right-click shortcut menu option and then just right-click anywhere on the chart to move the stops/targets to that price. Refer to the following: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
