Date/Time: Thu, 06 Mar 2025 16:03:50 +0000
Chartbook does not open
View Count: 628
[2022-02-09 15:51:03] |
User437588 - Posts: 69 |
Hello I have to reinstall Sierra Chart as it only opens in safe mode. When loading the previous chartbools SC always freezes on a chartbook. What is the problem? |
[2022-02-09 17:43:30] |
We do not know. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
