Date/Time: Mon, 10 Mar 2025 07:15:59 +0000
Cancel Orders on Flat Position
View Count: 922
[2022-02-09 15:50:12]
Steve Leon - Posts: 312
I have noticed recently that when I select Cancel Orders on a Flat Position that it does not save the choice for me when I log back into the platform.
It seems like I have to select every time.
This was not always the case.
Can you just let me know if I should expect this setting to reset evry time I shut the platform down.
Thank you
Steven Leon
[2022-02-09 17:45:31]
John - SC Support - Posts: 38516
Exactly which setting are you referring to?
[2022-02-09 21:17:37]
Under the trade menu window attached to the DOM. Menu button
-->Orders
-->Cancel Orders on Flat Position
It happened to me again this afternoon. I don't think I even shut down and restarted the platform ?
Thank you
[2022-02-10 19:31:13]
I am still having the same problem
The selection is definitely not holding
I turned the platform on. went to trade and had to reselect that option
This was not happening previously
I have not updated very recently
Thank you
Steve Leon
[2022-02-10 21:12:44]
Sierra_Chart Engineering - Posts: 18725
Maybe you are using Trade Window linking causing the option to be disabled from another Trade Window:
Working With Charts: Chart Linking
[2022-03-22 13:18:34]
i was able to resolve this question. I did not know i had to save this separately under each configuration
