Date/Time: Thu, 06 Mar 2025 16:36:06 +0000
SC Integration with IB
View Count: 601
[2022-02-09 15:28:56]
Rusty - Posts: 39
Can I trade CBOT products via the Teton Order Routing Service using the Denali data feed through my IB brokerage account 1) without installing TWS on my Windows platform, and 2) without installing Java on the platform? They just burn up bandwidth.
[2022-02-09 17:16:51]
Tony - Posts: 552
I have the same thought, bad news @ post #3:
Announcement: Sierra Chart Offers Low Latency Direct Zero Cost Futures Order Routing
I am running TWS, not sure how many instruments you are monitoring, mine
doesn't cause network traffic at all, TWS (java) does eat a lot memory,
but should be less than 1G, mine uses 700MB, which is acceptable, and CPU
usage is <5%. If it looks really bad, I would contact IB to find out
what's wrong.
Date Time Of Last Edit: 2022-02-09 17:22:23
[2022-02-09 17:40:21]
The answer to post #1 is no. You need to use a supported broker.
Date Time Of Last Edit: 2022-02-09 17:40:49
