Date/Time: Thu, 06 Mar 2025 16:35:24 +0000
Order routing in one instance with CQG/EUREX and Teton/CME
View Count: 494
[2022-02-09 09:24:12] |
User952036 - Posts: 16 |
Hi, I am using service pag. 11. Dorman Trading held my account, the IB is Tradovate. Can I use in one instance the cqg order routing for the EUREX and Teton for the CME or have I use one SC instance for the cqg routing and one SC instance for the Teton routing to the CME? Depending on what the answer is. What is the procedure to implement this: Teton for CME and CQG for EUREX? Regards, |
[2022-02-09 14:56:40] |
Yes you need two instances. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
