Date/Time: Thu, 06 Mar 2025 16:29:03 +0000
Add/remove open chartbooks on startup bug
View Count: 590
[2022-02-09 06:44:04] |
User772087 - Posts: 4 |
SC v2351 General settings - Startup - Open files on startup Add new Cht to the list works, however removing one Cht from the list changes the name of all next Cht files to the last one. example: list of chartbooks to open is RTY.CHT ES.CHT 6E.CHT 6B.CHT NQ.CHT Clicking 'remove' on ES.CHT will display the list as RTY.CHT NQ.CHT NQ.CHT NQ.CHT I have not tried saving the list to see how far this goes. Obviously in the big scheme of things this is not a big issue, but it would be good to have it addressed at some point. Thanks, |
[2022-02-09 10:03:56] |
We will check on this.
