Date/Time: Mon, 31 Mar 2025 08:45:31 +0000
Trade Activity Log format change?
View Count: 1031
[2022-02-08 21:36:36] |
traderacefly - Posts: 57 |
Hello, I use Tradervue to upload fills from the trade activity log. Uploads started failing after Feb 1, 22. I looked at the trade activity log file and it looks as though the log format has changed and thus not able to import trades to Tradervue. Just looking for confirmation from SC whether the logging format has changed in the SC Trade Activity Logs or not so I can alert Tradervue about this update.
[2022-02-08 23:09:27] |
bdunn - Posts: 19 |
Same issue. Also having issues with TraderSync.
[2022-02-08 23:15:35] |
New fields have been added. This is all.
[2022-02-09 02:10:53] |
bdunn - Posts: 19 |
The problem is coming up with TraderVue and TraderSync. I found a workaround. If you edit the exported file and change only the column titled "LogDateTime" to "DateTime" then it will be able to be imported. I hope that helps someone.
[2022-12-11 02:58:00] |
User513352 - Posts: 5 |
Tried this and still doesnt work . Anyone had any luck around this?
