Date/Time: Mon, 16 Sep 2024 19:06:53 +0000
Importing drawings from a different chartbook
View Count: 1070
[2022-02-08 20:46:23] |
User143517 - Posts: 68 |
Hi there, Is it possible to import drawings from one chartbook to another? Moreover, would it be possible to use the study/price overlay study in order to accomplish a similar action? Thank you. |
[2022-02-09 01:39:51] |
John - SC Support - Posts: 34450 |
Refer to the following for copying drawings between chartbooks: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) You can not use the Study/Price overlay for drawings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-09 09:15:23] |
Ok, got it. Regarding the Study/Price overlay,instead of drawings, would it be possible to overlay studies between chartbooks using it? Thank you. |
[2022-02-09 15:48:50] |
It is not supported to copy studies between chartbooks.
[2023-12-01 05:40:26] |
arul - Posts: 6 |
Is it possible to copy drawings between chartbooks?
[2023-12-01 14:53:58] |
Sierra_Chart Engineering - Posts: 16387 |
Yes it is. Refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
