Date/Time: Thu, 06 Mar 2025 16:13:59 +0000
ADR for custom time periods and text display
View Count: 953
[2022-02-08 18:48:27]
User8135477 - Posts: 133
I looked up the previous threads regarding a custom study for plotting the average (day) range.
However, I need my study to be specific to 4 different time periods (Regular Trading Hours, 24-Hour, Overnight, 1st Hour).
I do not need it to be plotted on the chart, but just need the text values.
I would like the Minimum, Maximum, Average, and the Previous Day's range within the preceding 10 days.
I have been doing this manually in my own spreadsheet after getting each values. I was wondering if there is already a similar custom study within Sierra Chart, and if not, would you be able to help set one up for me?
I've attached a screenshot of my spreadsheet setup.
Thank you.
Private File
[2022-02-09 01:07:16]
John - SC Support - Posts: 38439
There is not a study that does this exactly. But you can put together the studies to get what you need. In particular, you would need to have different charts for the different time frames you are wanting, and then use the ATR study to get your ranges. To display the information, you can use the Text Display for Study and Text Display for Study from Chart.
In order to get the previous information, you will need to use the Spreadsheet Study and get the information from there.
Refer to the following:
- For the Text Display for Study:
Text Display For Study
- For the ATR:
Average True Range
- For the Spreadsheet Study:
Using the Spreadsheet Study
