Date/Time: Thu, 06 Mar 2025 16:28:30 +0000
Order entry not accurate with interactive brokers.
View Count: 472
[2022-02-08 15:51:55]
User276793 - Posts: 55
I am having a problem when I buy GC futures the price does not coincide with he chart exaction price?
First i thought it was an issue with IB but then the same thing happened on simulated.
You can see when I bought the price excited much lower than the price displayed on the chart.
The chart price on Sierra lines up with price on IB and TOS (separate data source)so I do not think it is a data issue.
I have not check it it is the same on other tickers or chart books.
See attached:
imagegc problem.PNG / V - Attached On 2022-02-08 15:51:00 UTC - Size: 76.23 KB - 149 views
[2022-02-08 16:09:38]
Update: It seems to be gold futures (GC) that is having problems. Not sure how to fix this.. I will contact my broker as well but if you have any suggestion please....
