Date/Time: Fri, 11 Sep 2026 17:36:37 +0000
Fill 'Trade and current quote Symbol' with pattern matching
View Count: 723
| [2022-02-08 08:47:32] |
| User159282 - Posts: 3 |
Hi, Would it be possible to use pattern matching in Symbol Settings "Trade/Quote symbol" ? This pattern matching works for "Historical Chart Symbol" setting. For example in symbol settings for ****-NQTV: 1) Fill Trade/Quote Symbol custom setting as **** 2) This would automatically fill 'Trade and current quote symbol' in Chart Settings to the ticker name. COIN-NQTV would translate to COIN Thank you |
| [2022-02-08 10:26:30] |
We will see but this is not currently supported.
