Date/Time: Thu, 06 Mar 2025 16:37:10 +0000
Web based trading is logging off automatically
View Count: 441
[2022-02-07 16:48:28] |
User408880 - Posts: 3 |
I'm trying to login to web based trading so I can trade on my phone. After initially connecting the trading connection closes. The logs show "logoff received". About 1 out of 10 times it connects successfully and doesn't log off but when I try to switch from CME to another exchange such as COMEX it logs off again. No issues from the application.
Private File |
[2022-02-07 17:46:47] |
We will check on this and get back to you. We may need more information.
