Date/Time: Thu, 06 Mar 2025 16:15:41 +0000
Study: ask/bid volume difference bars
View Count: 1705
[2022-02-07 15:13:13]
countryboy92 - Posts: 91
I have this study at the bottom of my footprint chart with simple green and red bars (either red or green, not both combined). These bars are displaying up and down and are not level bottoms for both green and red bars which is taking up too much space. Can I format these so the bottom of each bar is level and the size of the bar shows how large it is in either red or green? I would like it be similar to a regular volume bar where the bottom of the bar is aligned along the X axis.
[2022-02-07 21:31:06]
John - SC Support - Posts: 38440
The Ask/Bid Volume Difference Bars are aligned to zero as each bar has an Open of 0. Then, if the Ask is dominant, the close will be positive, or if the Bid is dominant, then the Close will be negative. Therefore, the way these are displaying is correct.
If you want to see something different, such as Ask/Bid Difference as both positive numbers, then you would need to put together a collection of studies that can do this.
[2022-02-08 04:45:11]
I ended up adding ask/bid volume text study to display the amount on top of each bar. It is displaying with 2 decimal places; ie 236.00. How do I remove the decimal places?
[2022-02-08 12:24:54]
1+1=10 - Posts: 270
Study Settings -> Value Format (at left middle of initial settings screen.)
[2022-02-09 03:01:02]
Refer to:
Chart Studies: Settings and Inputs Tab >> Value Format
