Date/Time: Thu, 06 Mar 2025 16:23:58 +0000
Teton bracket orders with certain order types
View Count: 633
[2022-02-07 03:26:57]
User900285 - Posts: 98
I have noticed a slight discrepancy which I would like to share regarding attached orders.
I am on the Teton order routing service with Ironbeam.
1. When I place a parent limit order with an attached bid/ask quantity triggered stop, and I press a keyboard shortcut to perform 'Non-attached Limit Order Tick Up or Down'.
The limit order moves but the attached orders do not follow like they normally would in trade simulation mode or with past trade services I've used.
2. When I place a parent limit order with an attached stop order, and I press the same keyboard function 'Non-attached Limit Order Tick Up or Down'.
The attached orders now follow the parent order as they normally would be in trade simulation mode.
Apart from that I have noticed when I go to Trade > Trade Orders Window and I submit the first bracket with the bid/ask quantity triggered stop, the attached orders status for both the stop and target shows 'Pending Child - Client'. Which is normal since the bid/ask quantity triggered stop currently requires sierra chart to be connected on the client side in order for it to work.
When I submit the second bracket the status for the attached orders does show 'Pending Child - Server'.
This is not an urgent issue.
Date Time Of Last Edit: 2022-02-07 04:11:23
[2022-02-07 23:22:44]
Sierra_Chart Engineering - Posts: 18669
1. We will solve this.
