Date/Time: Thu, 06 Mar 2025 16:11:36 +0000
Open position labels to the right side
View Count: 1170
[2022-02-06 23:48:25] |
User200064 - Posts: 31 |
Hi Support, Is there a way to switch the labels on an open trade from the left side to the right side of the chart? Also, is there an option to display open PnL in currency or points on the open position line itself? I would like to make it look like the one in the attached picture. Picture with the gray background is my interface in Sierra Chart, picture with the black background is a third party platform, I want to achieve a similar look for my open positions Thank you |
![]() ![]() Attachment Deleted. |
[2022-02-07 18:28:00] |
John - SC Support - Posts: 38439 |
Refer to the settings starting at the following and the 2 entries after it: Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu) Also, is there an option to display open PnL in currency or points on the open position line itself?
Refer to the following setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
