Date/Time: Tue, 26 Nov 2024 04:38:02 +0000
Best way to send LOO - Limit-on-open Orders
View Count: 1293
[2014-04-12 20:15:29] |
YSS - Posts: 112 |
Hello, What would be the best way to send LOO (Limit-on-open) orders before market open? These are time in force type orders. Here's an example of the Interactive Brokers version: https://www.interactivebrokers.com/en/?f=%2Fen%2Ftrading%2Forders%2Floo.php I want to send a bunch of orders that are only going to be active when the market opens, not before. Thanks. |
[2014-04-14 18:42:15] |
This would have to be done using the automated trading functionality in Sierra Chart. You could probably do this with Spreadsheets: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
