Date/Time: Mon, 29 Jun 2026 21:43:10 +0000
Session Times
View Count: 849
[2022-02-06 22:51:51]
Steve Leon - Posts: 319
I am trying to have my session times set for all my charts using the times that i want
I changed this in the global settings under symbol but the charts are not changing to those times
Reason I aminterested in doing this is that i someting swith from Teto to CQG oreder routing and every time i do this the charts rvert back to some default times. I wind up changing the chartrs i really need manually to the time i want
Any suggestions on how best to deal with this
Thank you
Steven Leon
[2022-02-07 18:11:45]
John - SC Support - Posts: 46947
You need to do what you did, which is to change the default Session Times in the Symbol Settings. This way, when you change the symbol, the Session Times will be set the way you want.
But, these settings for the Session Times will only update a chart when you open a new chart, or if you change the symbol for the chart (which you are doing when you switch between Teton and CQG). Otherwise, the Session Times will not update, you would have to do that manually the first time.
Another thing to consider, if you are switching between Teton and CQG is to install a second Sierra Chart so you can keep one connected to Teton and the other to CQG. This is our recommended setup when you are using multiple trading services. This would eliminate the issue with the Session Times changing. Refer to the following for how install another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
