Date/Time: Thu, 25 Jun 2026 03:22:06 +0000
No CBOT data
View Count: 1159
[2022-02-06 20:57:14]
User437588 - Posts: 86
I do not receive CBOT data although the new version is installed.
What is the problem?
[2022-02-06 22:23:04]
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
[2022-02-07 08:56:21]
Software version: 2351 64-bit | 2022-02-07 02:51:25.695
Primary Thread ID: 2396 | 2022-02-07 02:51:25.695
Usage end date: 2022-04-18 | 2022-02-07 02:51:25.695
Enabled for: Advanced Features 2. | 2022-02-07 02:51:25.695
Enabled for: Sierra Chart Historical Data Service. | 2022-02-07 02:51:25.695
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-07 02:51:25.695
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-07 02:51:25.695
Enabled for exchange2: CME (Trading Account Required) | 2022-02-07 02:51:25.695
Enabled for exchange2: CBOT (Trading Account Required) | 2022-02-07 02:51:25.695
Enabled for exchange2: COMEX (Trading Account Required) | 2022-02-07 02:51:25.695
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-02-07 02:51:25.695
Enabled for exchange2: EUREX EOBI | 2022-02-07 02:51:25.695
Enabled for exchange2: fairx_exchange.data | 2022-02-07 02:51:25.695
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-07 02:51:25.695
Current selected Data/Trading service: SC Data - All Services | 2022-02-07 02:51:25.695
Custom symbol settings values: disabled | 2022-02-07 02:51:25.695
Chart Update Interval: 500 | 2022-02-07 02:51:25.695
Intraday Data Storage Time Unit: 0 | 2022-02-07 02:51:25.695
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-07 02:51:25.695
2022-02-07 08:51:25 Local computer time in UTC | 2022-02-07 02:51:25.695
2022-02-07 02:51:25 Local computer time in SC Time Zone | 2022-02-07 02:51:25.695
2022-02-07 08:40:13 Server time in UTC | 2022-02-07 02:51:25.695
Local computer UTC time and Server UTC time difference: 3 seconds. | 2022-02-07 02:51:25.695
Program path: C:\SierraChart\ | 2022-02-07 02:51:25.695
Data Files path: C:\SierraChart\Data\ | 2022-02-07 02:51:25.695
OS Version Number: 10.0 | 2022-02-07 02:51:25.695
Locale Setting: C | 2022-02-07 02:51:25.695
DLLs: sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, sst_twap.dll, sst_twap_64.dll, sst_value-at-price.dll, sst_value-at-price_2151_64.dll, sst_value-at-price_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2022-02-07 02:51:25.698
Allowed protected custom studies: SST_FreeBundle, SST_ValueAtPrice | 2022-02-07 02:51:25.698
CLH22-NYMEX [CBV][M] 60 Min #18 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\CLH22-NYMEX.scid. Error: Windows error code 112: Es steht nicht genug Speicherplatz auf dem Datenträger zur Verfügung. | 2022-02-07 02:53:58.080
CLH22-NYMEX [CBV][M] 60 Min #18 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\CLH22-NYMEX.scid. Error: Windows error code 112: Es steht nicht genug Speicherplatz auf dem Datenträger zur Verfügung. | 2022-02-07 02:53:58.572
Date Time Of Last Edit: 2022-02-07 14:51:35
[2022-02-07 09:59:06]
Tell me how can that be so that the Data folder has 298GB?
I find that quite a lot.
[2022-02-07 13:19:46]
User1293821 - Posts: 42
I am having similar issues. I get the candlestick bars to download, but my cumulative delta bars are way off / non-existent. I am using CQG with Denali Feed. It started about last Wednesday / Thursday.
You can see CME is working just fine and CBOT is not.
Date Time Of Last Edit: 2022-02-07 13:21:37
imageimage.png / V - Attached On 2022-02-07 13:18:42 UTC - Size: 76.66 KB - 252 views
imageimage2.png / V - Attached On 2022-02-07 13:21:30 UTC - Size: 136.68 KB - 259 views
[2022-02-07 14:54:47]
You have run out of storage space on your drive:
There is not enough space on the disk.
You need to solve this problem. This is critical. Delete unnecessary files. Instructions:
Chart Data and Chart Data Files: Deleting a Chart Data File
Once that is solved, then come back to us with any data issues.
You should also get a larger storage drive.
Regarding post #5, For CBOT you need to activate this exchange here:
Do not use this data from CQG but only the Denali Exchange Data Feed.
Date Time Of Last Edit: 2022-02-20 10:56:57
[2022-02-20 10:36:43]
Hello
Why do CBOT still need to be activated ? The complete CME group is activated incl. CBOT!
[2022-02-20 10:57:16]
Yes you are right about that. Are you having any difficulty accessing data now from the CBOT?
[2022-02-20 11:03:49]
Yes. SC can only be opened in Safe Mode with CBOT.
Without this mode SC freezes on startup with Cbot.
If I take out the CBOT charts SC starts as it should and does not freeze.
I do not understand this?
[2022-02-20 11:11:14]
In this case you must have an issue with a custom study. Refer to this help topic:
Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface
Date Time Of Last Edit: 2022-02-20 11:11:22
[2022-02-20 11:21:32]
Ok thanks.
I should now run the following command.
Move all files with a .DLL file extension in the Sierra Chart Data Files Folder into your DLLBackup folder that you created.
Unfortunately there are no DLL files in the folder.
Only scid dly files
[2022-02-20 12:13:16]
Therefore, Safe Mode should not make any difference.
The freezing must have something to do with the configuration of particular charts. Just do not use that Chartbook any longer containing those charts and create a new one.
Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
[2022-02-20 12:39:30]
I have already done that.
How do I get my drawings into the charts of the new Chartbook.
[2022-02-20 23:36:44]
There is no way to do this unless you can access the charts in your existing Chartbook. Try using another installation of Sierra Chart and open your Chartbook to see if you can open them without any issue. Refer to:
Using Multiple Data and Trading Services at the Same Time
Date Time Of Last Edit: 2022-02-20 23:36:51
