Date/Time: Thu, 06 Mar 2025 16:31:56 +0000
Advanced vs standard
View Count: 719
[2022-02-06 19:50:17]
CriticalSPX - Posts: 2
Hello, I signed up for standard service with denali feed, but order flow trading information is not available in my pacakge. Can you tell me which [ackage supports order flow and volumne profiles. username joseroig
[2022-02-07 18:06:07]
John - SC Support - Posts: 38443
You need to be on the Advanced package in order to get the Numbers Bars.
You are not setup to get any real-time data from the Denali Exchange Data Feed. What are the exchanges for which you want to have real-time data?
[2022-02-09 07:24:34]
Can I sign up for the advance package with real time data? I want ES MINI, basically CME data feed for ESH2 for example.
[2022-02-09 15:17:19]
Since you are wanting data from the CME Group, you need to be aware of their requirement that you have a live, funded, futures trading account that you can connect your Sierra Chart to in order to qualify for the non-professional exchange fees. For more information, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have a trading account that you can connect to, then we recommend the solution outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have worked out how you are going to handle the Professional/Non-Professional issue, then you will setup the Denali Exchange Data Feed by following these instructions:
