Date/Time: Thu, 06 Mar 2025 16:18:19 +0000
new screen 4k
View Count: 938
[2022-02-06 19:49:19] |
User334419 - Posts: 17 |
Hello, I have just changed my screen My new screens are in 4k quality and I would like to be able to optimize the display of Sierra Chart I currently have problems my work tabs are very small making it impossible to use the platform |
[2022-02-07 01:35:15] |
Tonkadad - Posts: 235 |
Right click on desktop (Win 10) and click "Display settings" look at your "Display resolution" try using the Recommended resolution. Try changing the percentage of the "Scale and layout" "Change the size of text, apps, and other items" Date Time Of Last Edit: 2022-02-07 01:35:34
[2022-02-07 18:29:41] |
John - SC Support - Posts: 38440 |
Check the font size for the Chartbook and MDI Tabs Text in the Graphics Settings. Refer to the following: Graphics Settings: Chartbook and MDI Tabs Text - (current font name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
