Date/Time: Wed, 12 Mar 2025 05:41:18 +0000
Bid/Ask Numbers (Text) - Draw DOM Graph on Chart Not Readable
View Count: 852
[2022-02-05 22:48:43]
user_xyz - Posts: 453
Could you all add some configuration/fine tuning settings for 'Show Volume Numbers'? Volume on/off on many charts is unreadable and showing all vol #'s isn't always helpful/useful. See attached.
Examples
* Show Numbers Greater than 'x' in Volume
* Show Numbers Greater than 'x %' Avg in Volume
* Numbers on left
Thank you it would be so helpful!
Date Time Of Last Edit: 2022-02-05 22:50:06
imageimage.png / V - Attached On 2022-02-05 22:44:26 UTC - Size: 80.31 KB - 210 views
[2022-02-12 19:34:03]
Any thoughts on this? The all or nothing on Draw DOM Graph isn't readable on most charts... Thanks
[2022-05-05 04:26:01]
Do you all think you can make some adjustments so the DOM numbers could be configured or readable?
imageScreenshot 2022-05-04 202325.png / V - Attached On 2022-05-05 04:24:57 UTC - Size: 247.59 KB - 159 views
[2022-05-05 14:12:58]
John - SC Support - Posts: 38598
We have this on our list of work items, but we can not say when we will be able to get to any particular item.
