Date/Time: Thu, 06 Mar 2025 16:29:21 +0000
Data speed btwn 2 chart books.
View Count: 565
[2022-02-05 21:06:37]
$teve.00 - Posts: 20
hi. I have 2 chartbooks. Chartbook 1 is the main chart with roughly 11 opened windows. The second chartbook is a smaller version of the first with only 4 opened windows. I created the second smaller version chartbook because the data speed on the dom was slow on chartbook 1. I assumed it was because chartbook 1 has too many opened windows.
So my question is, how do i get the data speed to increase in chartbook 1 so i don't have to refer to chartbook 2 for order flow?
Private File
Private File
[2022-02-07 19:55:27]
It is not within the scope of our support to be analyzing users Chartbooks in this way.
Use multiple instances to distribute your charts across instances, to distribute processing load:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
You can then view the Chartbooks at the same time. One in each instance.
Also refer to the instructions here and update to the latest release:
Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM (Improving Performance Of Chart / Trade DOM)
Date Time Of Last Edit: 2022-02-07 19:56:06
