Date/Time: Thu, 06 Mar 2025 16:18:03 +0000
Copying drawings across chartbooks
View Count: 830
[2022-02-05 03:07:27] |
User516084 - Posts: 13 |
I’ve been copying extended ray drawings that I manually draw from chartbook A to chart #1 in chartbook B without issue. Today, I noticed that the drawings were not copying over.there are some drawings that are still there further down on the charts that are not from today. It seems to be an issue with Chart #1. To test, I copied drawings to chart #2 in chartbook B, and it worked fine. What could be the issue? Chart 1 does have several overlays from other charts in it’s own chartbook. |
[2022-02-07 15:44:50] |
Refer to the information here: Chart Settings: What to Do If Chart Drawings Do Not Copy (What to Do If Chart Drawings Do Not Copy) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-07 15:45:11
