Date/Time: Tue, 22 Sep 2026 22:58:07 +0000
Switching to Sierra Chart Teton Future Order Routing Service
View Count: 960
| [2022-02-04 23:31:04] |
| User924806 - Posts: 20 |
I am trying to switch to Sierra's order routing service but doesn't give the option to select AMP from the Clearing Firm list so I got stuck...I am requesting some detailed instructions to make the change. I have already sent this request for support to the Account Support portal but I got no answer so far. Please address this issues asap! Thank you! |
| [2022-02-07 15:14:35] |
| John - SC Support - Posts: 47980 |
AMP does not currently support the Teton Order Routing Service, so you can not use it with AMP. In order to use Sierra Chart with AMP, you will need AMP to setup your account to use either CQG or Rithmic for your order routing. Then follow the appropriate setup instructions depending on which one you are setup with. For CQG: CQG Trading Platform Service: Setup Instructions For Rithmic: Rithmic Trading Platform Service: Setup Instructions -- In either case, we recommend using the Denali Exchange Data Feed for your data. Refer to the information (including Setup Instructions) at the following link: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-07 15:22:45] |
I am using CQG through AMP at this time but I's like to switch to Teton from Sierra Charts...So I won't be able to switch at this time because AMP doesn't support it or there is a way around it?
| [2022-02-07 22:31:16] |
You can not stay with AMP and switch to the Teton Order Routing, as AMP does not support it. Therefore, if you want the Teton Order Routing Service, you would need to switch brokers. Refer to the list of brokers at Step #2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Otherwise, if you stay with AMP, then you can continue to use Sierra Chart, but you will have to stay with CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
