Date/Time: Thu, 06 Mar 2025 13:13:41 +0000
Delete and Re-Download All Data for All Symbols in Associated Watchlist
View Count: 1152
[2022-02-04 18:00:16] |
fykemang - Posts: 49 |
Do you guys have a way to delete and re-download all data for symbols in associated watchlist? I am asking because I was scanning 2000+ stock symbols but somehow historical data did not download properly for all of them but I still have fragments of real-time data with tiny candlesticks. I would like to re-download the historical data for all of them. Using the currently available options does not allow me to "reset" the symbols.
[2022-02-04 18:28:54] |
John - SC Support - Posts: 38425 |
Refer to the following: Edit Menu: Edit >> Download Data for Associated Watch List Symbols Also note the one above it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-04 19:30:19] |
I know that I can do that. The problem is if the chart receives real-time data which is newer. Data is only updated from the latest Date-Time. Therefore I have a bunch of charts for which I can't recover data unless I manually do Edit >> Delete All Data And Download manually for each of the 2000 symbols. There is basically a gap in the symbol data right now. Edit >> Download Data for Associated Watch List Symbols does not fix this issue. Also, given the fact that there are issues with volume data for the NQTV data feed, I believe it would make sense for a bulk delete and download data option. Once you guys fix all the volume issues, I will want to re-download data for all my stock charts. There are many more stock symbols than futures symbols. Date Time Of Last Edit: 2022-02-04 19:38:27
