Date/Time: Thu, 06 Mar 2025 16:14:35 +0000
Sierra3.cfg format to Sierra4.config
View Count: 648
[2022-02-04 17:31:33]
User763002 - Posts: 30
Is it possible to convert Sierra3.cfg file to Sierra4.config file? I received a global settings file and want to implement it on my local machine, but there is a mismatch on file types.
Is it as simple as renaming the file correctly or is there something more involved then that?
[2022-02-07 22:55:30]
You need to exit from Sierra Chart and delete the Sierra4.config file, in the older format file will be converted automatically when you start Sierra Chart again.
