Date/Time: Thu, 06 Mar 2025 12:58:28 +0000
Need your live assistance please...
View Count: 421
[2022-02-04 15:13:30] |
User280059 - Posts: 14 |
I have been using SC for many years but just today have encountered a serious problem with the control bar and I cannot, after many hours of trying, correct this problem and it is also affecting my chart windows. I have never seen this before and I'm pretty sure I cannot fix this myself. Please advise me how to set this up with you as soon as possible. I hope you can help me soon. Thank you. |
[2022-02-04 16:02:35] |
What is the problem with the control bar? Is it too large?
[2022-02-04 16:35:23] |
Thanks for getting back to me. When I click on the SC icon I usually get the control bar and when I minimize the control bar it usually appears at the top of the list of reduced charts. Now it appears at the bottom and it takes time to reach it in order to be able to save and rename the chartbook I am updating and saving. It also now disappears beneath my various charts. The first step I guess would be to learn how to move the control bar back to the top of the list of minimized charts. Then I guess it would be smart to reduce the size of the minimized chart list. I'm sure this must be the result of some mistake I made inadvertently on my keyboard. I could not find a solution on the Support Board. Thanks for your assistance.
