Date/Time: Sun, 24 Nov 2024 04:52:52 +0000
[User Discussion] - Hide Price Label?
View Count: 2762
[2014-04-11 15:53:00] |
OneMoreTick - Posts: 79 |
Is it possible to hide the price label? I have some volume profile charts where I don't want to see it
[2014-04-11 16:31:58] |
Do you mean the last trade price on the right side of the chart in the Values Scale? If so, the answer is no.
[2014-04-11 16:41:39] |
Yes, that's what I meant. Can I change the colors of it then?
[2014-04-11 16:46:21] |
Yes. Through Global Settings >> Graphics Settings.
[2014-04-11 16:50:40] |
Dang, wanted to make the box transparent but doesn't look like that's an option.
[2018-10-12 02:16:42] |
abn2609 - Posts: 15 |
Can you hide the symbol label and time frame label that appears at the top WITHIN the chart? Since it already appears on the top on the windows frame...it's just pointless reading it twice... Also want to hide the number of the chart, and the Close price which I already have as the price label... Thanks SC |
[2018-10-12 14:36:25] |
Refer to the following documentation for changing what is displayed in the Chart Header: Working With Charts: Region Data Line / Chart Header
[2018-10-16 00:24:54] |
User750920 - Posts: 278 |
@OneMoreTick- maybe you solved this but to effectively make it transparent yo could change the foreground to the same color of the chart background and the price itself to the same color as the rest of the price scale (default is white).
Date Time Of Last Edit: 2018-10-16 00:25:25
[2018-10-20 22:47:36] |
whats1thingnow - Posts: 407 |
i also want remove the last price from the Values Scale i can't see the labels that are on my Values Scale because the 'last trade price' is hovering on top them :( |
[2020-04-21 20:08:42] |
also want remove the last price from the Values Scalei can't see the labels that are on my Values Scale because the 'last trade price' is hovering on top them :( anyone know how to do this? thanks |
[2024-06-24 02:19:03] |
LudaTrades - Posts: 26 |
Graphics Settings >> Last Trade Price Box >> Uncheck Enable
[2024-06-24 14:08:23] |
Tony - Posts: 516 |
Not sure hiding Value Scale would be an option for you: Chart Settings -> Scale -> Hide Values Scale -> Yes |
