Date/Time: Thu, 06 Mar 2025 13:03:35 +0000
4 seconds delays
View Count: 601
[2022-02-04 14:08:40] |
User432142 - Posts: 44 |
hi, after updating sierra l have issue that time is delaying. between time of platform and remaining time indicator doesnt synchronize |
[2022-02-04 14:39:25] |
Make sure your computer's clock is set accurately: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-04 14:39:31
[2022-02-05 02:26:41] |
User90125 - Posts: 715 |
Another way to sync the time on your computer is to use a third-party software such as Dimension 4.
