Date/Time: Thu, 06 Mar 2025 12:42:45 +0000
display open marker in weekly TPO
View Count: 665
[2022-02-04 11:24:57]
retox - Posts: 3
I'm using a weekly TPO Chart. I've set an open marker color in the subgraph settings. This Open TPO is very small and sometimes I can't see it. How can I change the size of the open marker TPO?
attached you'll find some screenshots.
imageopenmarker.png / V - Attached On 2022-02-04 11:23:43 UTC - Size: 248.02 KB - 195 views
[2022-02-04 15:55:30]
John - SC Support - Posts: 38425
It only colors the one Block/Letter that represents the Open. Therefore, when you have a very dense profile like you do, you may not be able to see the Open. You need to increase the Letter/Block Price Increment in Ticks in order to group TPOs together to make them larger and hence more visible. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks
