Date/Time: Thu, 06 Mar 2025 13:02:28 +0000
Missing Cumulative Delta Data
View Count: 854
[2022-02-04 07:25:02]
User926524 - Posts: 8
After updating Sierra Chart the charts does not longer show the Culmulative Delta during times I shot down my computer. See attached image. I tried "Delete all Data and Download" but then all historical Cumulative Delta data is gone. I installed the previous version but the data is still missing. How should I proceed. Thank you.
image2022-02-04 08-05-13-.png / V - Attached On 2022-02-04 07:23:59 UTC - Size: 156.7 KB - 141 views
[2022-02-04 12:37:24]
Refer to the notes for version 2351 here regarding CQG historical tick data:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351
Date Time Of Last Edit: 2022-02-04 12:37:44
[2022-02-04 13:48:31]
Thank you. Cumulative Delta Volume is not working, Cumulative Delta Up/Down Tick works, also for the last two months, so I believe its a technical problem.
For my understanding, If I stay with AMP and and activate Denali with Sierra Chart, I need to pay CME fees via Sierra Chart, correct?
[2022-02-04 16:37:52]
John - SC Support - Posts: 38425
If you use the Denali Exchange Data Feed, you will need to pay for the exchange fees through us. You can then stop the exchange fees through your broker.
You will find the instructions to setup the Denali Exchange Data feed at the following link:
