Date/Time: Sun, 16 Mar 2025 19:01:30 +0000
How to use trading levels study
View Count: 1789
[2022-02-04 06:47:39] |
Flowdity - Posts: 50 |
Support team enabled trading levels study for me https://www.sierrachart.com/UserControlPanel.php?page=ManageCustomStudiesDLLUsers&SCDLLName=FadeTheExtreme_Index_levels When I added trading levels study, for "Request Identifier" field do I fill in the name that I have "FadeTheExtreme_Index_levels" also https://www.sierrachart.com/UserControlPanel.php?page=SetPriceLevels&SCDLLName=FadeTheExtreme_Index_levels in this page when i was trying to add a second level, it shows an error "Error adding new Price Levels for ESH22_FUT_CME ->" |
[2022-02-07 23:11:05] |
When I added trading levels study, for "Request Identifier" field do I fill in the name that I have "FadeTheExtreme_Index_levels" We will check on this for you: in this page when i was trying to add a second level, it shows an error "Error adding new Price Levels for ESH22_FUT_CME ->"
[2022-02-08 13:44:03] |
Also I would like to know how many levels I can add?
[2022-02-11 12:31:27] |
This pending review still.
[2022-02-11 15:05:07] |
There is no limit to the number of values to enter. Please let us know what values you were entering. Sierra Chart Support Date Time Of Last Edit: 2022-02-12 18:53:38
[2022-02-11 18:46:18] |
I was trying to add one more levels for ESH22_FUT_CME. If it works i will add more that I need The other day I tried to add levels for NQH22_FUT_CME, it showed an error for me. |
[2022-02-12 18:54:34] |
Please let us know what were the values? And what the error. We need to be able to replicate this to be able to see what is causing the issue. Sierra Chart Support |
[2022-02-13 17:16:41] |
I was adding 4813 for ESH22_FUT_CME
[2022-02-15 22:21:29] |
Did you enter a date, or was that blank?
[2022-02-16 00:14:30] |
Yes I left it blank. That’s the issue, just tried entering with a date it works Now I just need to use “ FadeTheExtreme_Index_levels” as the study input right? |
[2022-02-16 02:20:24] |
in the input name for trading levels study I put "FadeTheExtreme_Index_levels" in requet identifier I have two levels from the management page. subgraphs draw style I updated as line, but I still dont see lines on the chart. I found out after the period "request interval in minutes" the draw style gets updated to ignore automatically. |
[2022-02-18 14:51:56] |
We will do some testing of this. What is the symbol of the chart?
[2022-02-19 00:54:26] |
Symbol is ESH22_FUT_CME
[2022-03-04 18:11:48] |
We apologize for the delay here. Are you using the trading levels just for your own use or are you sharing levels with other users? We are working on a whole new method to share trading levels, through real-time Chartbook sharing. This is in development now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-05 00:53:34] |
I’m using for myself and a friend That’s cool. As this is not working as expected I’m using horizontal lines study as a workaround Looks like trading levels study is just like horizontal lines. But not sure setting levels not working in the management page |
[2022-08-15 14:46:06] |
User275592 - Posts: 97 |
hi any news about the new way of sharing levels via real time chartbook sharing ? thank you for your help |
[2022-08-24 18:59:15] |
Sierra_Chart Engineering - Posts: 18799 |
We apologize. We have not been able to allocate further time to this. Related to this, our time has been working on real-time Chartbook sharing. We are doing our best to get this out in September. We are determined to do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-24 19:02:25
[2022-08-24 19:41:48] |
thank you very much for the good news !
[2022-08-25 09:51:31] |
I’m using a custom study loading from google sheet now. If anyone wants to use please check this one https://github.com/FrozenTundraTrader/sierrachart/blob/main/google_sheets_importer.cpp |
[2022-08-25 19:51:47] |
hi, does your study loads each time there is an update on the google sheet ? thank you for your help
