Date/Time: Thu, 06 Mar 2025 12:56:25 +0000
Nasdaq DOM levels capped at 25
View Count: 569
[2022-02-04 01:30:38] |
User504778 - Posts: 22 |
First of all thank you for introducing NASDAQ TotalView data feed. Have been waiting for this for 2 years. I can see 25 levels of bid and 25 levels of ask orders in DOM window from the new Nasdaq feed. I need to see more, and tried setting Chart Settings->Advanced Settings 3->Maximum Market Depth Levels to 0 or 100, but it has no effect. I heard there should be up to 1400 levels available? Anyway I can see more than 25? BTW, I'm testing with delayed data using Service Package 3. Thanks. |
[2022-02-04 02:37:18] |
frozentundra - Posts: 94 |
What symbol are you looking at? I am seeing well over 25 here, I wonder if you have something in Global Symbol settings or another settings area capping you? Can you post a screenshot of a chart where you're seeing 25 levels, max?
[2022-02-04 03:34:50] |
Regarding this, refer to this section here: File Menu: Not Receiving the Full Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-04 14:39:43] |
Thank you. Issue resolved by following your instructions. It was caused by the Global Settings >> Sierra Chart Server Settings >> Max Depth Levels. Now I can see hundreds of levels.
