Date/Time: Thu, 06 Mar 2025 15:56:16 +0000
how to find a study you have saved
View Count: 910
[2022-02-03 19:34:19]
User449884 - Posts: 166
hello,
Someone has sent me a chartbook, and id like to save and transfer a couple studies from it onto my own chartbook. I saved the study in question, i see it in sierrachart/data under .stdycollct.
However when i go to my chart book and go into add custom study i do not see it anywhere,
Appreciate any help
[2022-02-03 20:28:00]
John - SC Support - Posts: 38434
Refer to the following for how to use Study Collections:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
[2022-02-07 02:45:43]
thanks, when i save the study, and load it on the chart i want to add it onto, the previous studies on that chart disapear
[2022-02-07 18:34:07]
You will want to apply that Study Collection and then resave it with a plus sign at the end (+) that denotes that it should prompt whether to remove the other studies or not. Refer to the following:
Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies)
